August 19, 2019 at 8:46 am
Lumpine
SubscriberHello,
I am simulating an rigid body which is moving throug a fluid. The fluid is a remeshing zone and consists of two different phases.
Now I am trying to refine the interphase of the two phases. Therefore i created a cell register and choose the zone over Density and Derivative Option Gradient. After that i choose this zone in refinement criterion.
The problem is that the dynamic mesh doesn't work if I use this refinement criterion. Without the criterion it works fine.
Can anyone help me. Is it possible to use the gradient adaption and the dynamic mesh at the same time?
Thank you very much!
August 20, 2019 at 10:19 am
Ansys EmployeeHave you checked compatibility of adaption and dynamic mesh?
August 20, 2019 at 10:22 am
Lumpine
SubscriberThanks for your response!
How can I check compatibility?
August 20, 2019 at 12:30 pm
Ansys EmployeeIt's usually covered in the User's or Theory Guide under limitations. You may need to check sections adaption and dynamic mesh as (helpfully) it may not say in both sections.....
2524
2066
1279
1096
457
