Gradient Based Optimizer error
    • desouzadacosta
      Hi All,
      I am trying to start an adjoint optimization cycle using the Gradient Based Optimizer interface.
      However it is echoing the following message in the TUI:
      ** Unable to proceed: No valid observable has been specified
      I pretty much defined the observable as the following image :
    • wcao
      Hi there,nI wonder if you have obtained a solution of gradient via adjoint solver first? Usually you will need to obtain one gradient solution via adjoint solver manually first before using the optimizer. Thanks.nBest,nWeiyun
