January 24, 2023 at 7:02 pm
ehsan.sadeghi
SubscriberI want to calculate the gradient of UDS0 and save it in a UDMI to later use it in the UDF. I calculate the cell values of gradient of UDS0 by using C_UDSI_G macro and save it to UDMI. i.e.:
C_UDMI(c,t,0) = -1.*C_UDSI_G(c,t,0)[0]; //Ex
Based on UDF manual tha face value of an scalar is calculated by:As there are no macros (as far as I know) to give me the face values of scalar so I do the next for boundary faces:
BOUNDARY_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0)
F_UDMI(f,t,0) = C_UDMI(c,t0,0) + (C_UDSI_G(c0,t0,0)[0]*dr0[0]);Is it a correct way of calculating the gradient? my code compiles corrrectly but after one iteration fluent gives me an error message like this:
Node 0 Fatal signal raised sig = Segmentation fault
January 25, 2023 at 11:10 am
Ansys EmployeeThere's a flag in the code to retain gradient data after it's used in the solver. If you don't some of the gradients aren't there to use in UDFs.
/solve/set/advanced/retain-temporary-solver-mem and "yes" when asked.
This assumes you have sufficient UDM and UDS assigned in the case.
January 26, 2023 at 8:51 am
ehsan.sadeghi
SubscriberThanks Rob. It was memory related issue. I retained the memory from freeing. One question more: is it the correct way of calculating gradient? comparing electric field (i.e. gradient of UDS0 or gradient of potential) with MHD module I get slightly different results .
January 26, 2023 at 4:41 pm
Ansys EmployeeI tend to use the Fluent macros. Remember scalars diffuse so depending on how the MHD module is coded up (UDM rather than UDS) there may be a difference.
January 26, 2023 at 7:04 pm
ehsan.sadeghi
SubscriberI didn´t get exactly what you mean. Considering that the potential equation or Poisson´s equation take diffusion coefficient of 1 (depending on how you incorporate source term), do you mean that partly the result accuracy will depend on discretization scheme of UDS? second order schemes should minimize false diffusion no?
January 27, 2023 at 1:13 pm
Ansys Employee2.2.1.4 https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_udf/flu_udf_GeneralSolverDEFINE.html
A UDS is a scalar, similar to species, so as well as convection it'll diffuse with the flow. A UDM is a calculated value in a cell, it can only "move" based on what maths creates it.
January 27, 2023 at 5:12 pm
ehsan.sadeghi
SubscriberBut it doesn´t explain why there are differences in MHD and UDS for potential equation. With same diffusivity and BC it should produce same results. That is why I am suspecting that the way that I am calculating gradient is not correct, perhaps gradient on faces. Fleunt´s MHD documentation is very breif and there are no macros related to MHD in the manual.
January 30, 2023 at 11:13 am
Ansys EmployeeYes, we tend not to share everything, and I can't comment other than to refer to the manual(s). Look for [123] or similar in the documentation, that'll be a reference to the theory. If the results are close, you may be right, but I suspect you've missed something more significant.
2700
2138
1355
1142
462
