gradually applied load in Ansys .
    • brotherhood
      how to apply load in Ansys on the beam in increments from zero to certain value in increment form ?
    • peteroznewman
      One simple way is under Analysis Settings, turn on Auto TIme Stepping.
      Set the Initial, Minimum and Maximum substeps to 20. Now you will have 20 increments in the solution.
      Another way is to change the number of steps t0 20, but then you have to type out the 20 values of load in between zero and the final value.
