Ansys Products
Ansys Products
Granta EduPack 2020 licensing question
    • kindires
      We have Granta EduPack 2020 (Ansys licensing). Ansys license is installed and working. The ports 1055 and 2325 are open to the clients. Granta seems to install fine, but when we try to run the software, we see ""Your license could not be loaded. Please check your license settings, including license server configuration."
    • ANSYS_MMadore
      Please check your C:\Program Files (x86)\GRANTA EduPack\Shared Files\Licensing\ansyslmd.ini file to ensure it lists the correct server details.nExample:nSERVER=1055@licenseservernANSYSLI_SERVERS=2325@licenseservern
    • kindires
      Thanks for the response. This did not help. We have the correct information in the ansyslmd.ini file. Those ports are also open to the client.nA question: In the license file, hostname is shown as ansys-license (the first line in the license file: SERVER ansys-license DISK_SERIAL_NUM= 1055). But ansys-license is not the full domain name. Does it need to be the full domain name? If so, can we change it?n
    • ANSYS_MMadore
      Are the ports open on the SERVER?nIt does not need to be the full domain name, unless the client machines cannot resolve the server as ansys-license. If it can't be resolved by clients, please do revise the hostname in the license to match the FQDN.n
    • kindires
      Thanks again. Yes, the ports are open. We generally do a telnet test from the clients to the server with port numbers (telnet ). This works. nI changed the server name to FQDN. The license manager does not want to load the file because it thinks it is the same! How do I remove a previous license and reload a new one? Also, how do we see if the client is contacting the server? None of the license log files seem to show it.n
    • ANSYS_MMadore
      You can stop the license manager, edit the file and save it, then restart the license manager. Or you can edit, save to your desktop, delete the existing ansyslmd.lic, then use the ANSYS License Management Center to install the modified file saved to your desktop.nPlease check to see if the Client has the ANSYSLI_ELASTIC or ANSYSLI_LCP environment variables set, if so please try removing them.n
    • kindires
      Thank you again for your help. Unfortunately none of this has helped. The env variables are not set and replacing the license file with FQDN did not help. Do you have any other suggestions? What should we look for on the server when the client is trying to contact the server?n
    • tsiriaks
      Check the other port for ansyslmd , which is dynamic by default. This must be open between client and server too.nYou can set the ansyslmd port to be static , by going ton(Windows) C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files n(Linux) ../ansys_inc/shared_files/licensing/license_filesnand modify the VENDOR line in every .lic filesnso that it looks like thisnVENDOR ansyslmd PORT=1056n(of course, you can use other port aside from 1056 as well)nPlease make sure that you restart the ANSYS License Manager after you edit this.nIf this doesn't help, you probably have DNS issue. We can discuss further if it comes to this.n
    • kindires
      Yes, it was the third dynamic port issue and we fixed it by making 1056 static. Thanks! We had come across the same solution via another post on the Ansys forum:nn
    • tsiriaks
      Great ! Thank you for the update. Also thanks for searching past threads.n
    • paltobelli
      Hello, i'm having the same issue. I've installed Granta EduPack on a test pc. i get the same errorYour license could not be loaded. Please check your license settings, including license server configuration.nLicense seems to be running fine on the server. I've even installed Ansys Fluent on the same PC and it seems to work fine.nAny help would be greatly appreciated. Would like to get Grant working since students have been without for the past few days.nnThanksn
    • tsiriaks
      Check if your license file has this granta_edupack license feature (the one on the INCREMENT line)nIf so, check the networking just like what discussed here. You need two ports to be open between client and server machines : one is 1055 by default, the other is dynamic defaultn
    • paltobelli
      Hello,nI did check the license file and it does have the increment granta_edupack (INCREMENT granta_edupack ansyslmd 9999.9999 31-aug-2021 50 \)nAs for the networking part, not sure what you mean? my license file looks like this (removed some info)nSERVER XXXXXXXXXX DISK_SERIAL_NUM=XXXXXXX 1055nVENDOR ansyslmdnUSE_SERVERnnWhy would Ansys CFD be working ok on the same computer?nThanks againn
    • paltobelli
      Hello,nnI managed to get it working. Thanks for your responsen
    • tsiriaks
      Mech/CFD are using a different port (2325 by default).nThat's why I told you to check the other two ports for your Granta issue.n
Viewing 14 reply threads
