March 7, 2022 at 9:57 am
Sanne
SubscriberHi there,
Since yesterday my Granta Edupack isn't working anymore. Due to an error that has something to do with the FLEXlm server I suppose?
March 8, 2022 at 12:34 pmGeorge Karnos
Ansys EmployeeThis could be a firewall issue.
Try shutting down your firewall to se if you can run.
What happens if you run Client Licensing Utilities and try to perform a Flexnet Publisher License Status?
March 8, 2022 at 4:49 pmSanne
SubscriberI disabled my firewall, it doesn't work.
If I peform a Flexnet Publisher License Status I get this:
1055@---------
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
Flexible License Manager status on Tue 3/8/2022 17:45
[Detecting lmgrd processes...]
License server status: 1055@wi690-sep
License file(s) on wi690-sep: 1055@--------
lmgrd is not running: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
I removed the license that i got and put stripes instead.
I hope this says something to you but i can't make anything out of this {'-__-}
Kind Regards Sanne
March 8, 2022 at 7:22 pmGeorge Karnos
Ansys EmployeeOpen a Dos command prompt and type in the following:
ping -----
Where ----- is the name of your license server
March 8, 2022 at 7:29 pmSanne
SubscriberIt says :
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss) Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 11ms, Average = 10ms
March 8, 2022 at 8:10 pmGeorge Karnos
Ansys EmployeeIs the server name listed in the c:\program files\Ansys Inc\shared files\licensing\ansyslmd.ini file
usually this issue has to do with firewall blocking
Has anything changed on the license server end?
Can others check out licenses?
March 8, 2022 at 8:17 pmSanne
Subscriberit is listed, and the other students can use the license
March 8, 2022 at 8:23 pmSanne
SubscriberAlltough my map name is different, its called granta instead of Ansys Inc.
But that is not a problem right?
March 8, 2022 at 8:36 pmGeorge Karnos
Ansys EmployeeC:\Program Files (x86)\GRANTA EduPack is fine Can you ping
wi690-sep
Are you using an ip address in the server specification?
March 8, 2022 at 8:42 pmSanne
Subscriberping request could not find wi690-sep
March 8, 2022 at 8:43 pmSanne
SubscriberIm using a school vpn
March 8, 2022 at 8:44 pmGeorge Karnos
Ansys EmployeeIs that the license server hostname?
The others that can run, are they pointing to the same machine?
March 8, 2022 at 8:48 pmSanne
Subscriberits a cesedupack.license.schoolname.nl
March 8, 2022 at 8:50 pmSanne
Subscriberwe need to fill it in when installing granta edupack when asked for server and port.
March 8, 2022 at 9:00 pmGeorge Karnos
Ansys EmployeeVerify that the hostname in the ansyslmd.ini under:
C:\Program Files (x86)\GRANTA EduPack\Shared Files\Licensing
matches the license server hostname
March 8, 2022 at 9:07 pmSanne
Subscriberi don't understand, u mean the ip-adress? or the license server that i filled in in the installation?
SubscriberCause i can find this in the file:
March 8, 2022 at 9:08 pmSanne
Subscriber[-]
SERVER=1055@cesedupack.licentie.-------.nl
ANSYSLI_SERVERS=2325@cesedupack.licentie.------.nl
March 8, 2022 at 9:32 pmGeorge Karnos
Ansys EmployeeDo you have a ansyslmd.ini file under:
verify the same.
Im wondering why the license status was pointing to a different server
March 8, 2022 at 9:45 pmSanne
SubscriberI dont have a map in program files only in program filesx86.
Granta Edupack\shared files\licensing\ansyslmd.ini
March 9, 2022 at 2:26 amGeorge Karnos
Ansys EmployeeCan you open a dos window and type in:
set A
post the output please
March 9, 2022 at 5:23 amSanne
SubscriberC:\Users\koolm>set A
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\koolm\AppData\Roaming
March 9, 2022 at 6:34 amSanne
SubscriberI am at my internship right now and there the program is working just fine !
I need to make it work at home as well, since i need it for my schoolcourses.
What might be the problem?
March 9, 2022 at 12:14 pmGeorge Karnos
Ansys EmployeeNeed to confirm with the school if cesedupack.license.schoolname.nl is an alias for wi690-sep.
The status indicates the server has wi690-sep in the license file. If you can't resolve that hostname
you should try the ip address or add a hosts file entry for the ip address and hostname.
You may need to work with School IT Department.
Viewing 23 reply threads- You must be logged in to reply to this topic.
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2656
2120
1349
1118
461
