GRAPH B/W DEFORMATION VS APPLIED LOAD AT SPECIFIC POINT ?
    • brotherhood
      How I will get deformation vs applied load graph at specific location on the beam in ANSYS ?n
    • SaiD
      Hi,nIf the specific location is a node, then you can create a Named Selection with just that particular node in it. Then you can define the Deformation of that Named Selection to get the deformation of that node. nGenerally, charts are used to plot the graph of two variables.nnHope this helps,nSain
