December 20, 2022 at 12:50 pm
December 20, 2022 at 5:57 pm
Guilin Sun
Ansys EmployeeCould you please try another file and check if it works?
If not, please upgrade the software. You may also need to restart your computer.
It might also be related to the computer. We have not received bug report for this. If the problem still exists, please send us a support email (after upgrading to the newest version) so we can test.
- Error on Lumerical device
2688
2138
1355
1140
462
