June 17, 2019 at 10:07 am
andrzej.tusk
SubscriberHello
I'd like to upgrade Graphics card in my Ansys Discovery Live workstation.
Currently I have Quadro P5000.
Calculations often have many low thickness walls with internal fluid flow.
I'm thinking GP 100. I have budget of around 5000 - 7000 USD
What would be best choice efficiency vs cost
June 17, 2019 at 10:49 am
Naresh Patre
Ansys EmployeeHello Andrzej Tusk
Quadro P5000 and GP100 both seem to have 16 GB GPU memory while the latter one has higher CUDA cores. If the thin regions in your model are not getting resolved with Quadro P5000 model, I doubt they will get resolved with GP100 as Discovery Live has some limitations while handling thin regions. Please check out below post on handling thin geometric features in Discovery Live If you haven't done so. Meanwhile, I will also check with the team and will let you know.
June 18, 2019 at 5:11 am
Naresh Patre
I got the same response from team that it cannot be guaranteed whether upgrading to a higher GPU memory (from Quadro P5000 16 GB GPU memory) will capture thin regions in your model. As mentioned in the "thin geometric features" post shared earlier, please check if you are able to reduce the domain size for capturing thin regions.
June 18, 2019 at 12:08 pm
andrzej.tusk
SubscriberHello Naresh Patre
Thank you for your response.
So GP100 is not the way. What about two nv Linked RTX cards or GV100 or P6000 will this help?
June 19, 2019 at 5:21 am
Naresh Patre
It's difficult to tell if any of the higher GPU memory cards like GV100 (32 GB) will be able to capture all thin sections in your models. Currently Discovery Live has some limitations while handling thin regions.
June 19, 2019 at 6:09 am
andrzej.tusk
At the moment Discovery Live captures my thin regions well, but fidelity settings has to be high (top 75%+). I'd like to achieve one of two effects with this upgrade:
1) Faster calculation with current fidelity setting2) Ability to lower fidelity setting while still capturing thin regions therefore making calculation faster
At the end higher calculation speed is the target.
Can any hardware upgrade support that?
June 19, 2019 at 7:42 am
Naresh Patre
Good to know that the thin regions are being captured. How much time (elapsed time on your machine and not the simulation end time) does it currently take to get the results with highest fidelity?
June 19, 2019 at 8:54 am
andrzej.tusk
SubscriberHello for some models we wait up to 2 hours to see indication of the results. If we want really fine results we go for 8h. We mostly build air handling devices made of sheet metal.
June 19, 2019 at 10:02 am
Naresh Patre
Thanks for sharing the details. I am checking with the team and will get back to you. Meanwhile, Do you monitor any solution parameters (like outlet velocity) through charts? Does the graph stabilize after 2hrs / 8hrs, or do you see the values stabilized much earlier? If the latter is the case, you may consider the results as finalized and may want to stop the solution from solving further.
June 19, 2019 at 10:15 am
Naresh Patre
Is it possible for you to share your model for the development team to look into? You can attach it here which could also be visible to all forum users. If the model is confidential, I can contact you separately for sharing the model. Let me know.
3862
2639
1859
1254
600
