Ansys Products
Ansys Products
Graphics is not available unable to render .
    • vivek310
      I installed ansys 20 and I ran spaceclaim and got this error and after this I even changed settings in advance tab still error is coming plz help (I'm using windows 7 professional in Virtualbox installed in MacBook Air )
      i
    • tsiriaks
      VirtualBox is probably not good enough to pass graphics to the Guest OS (Windows in this case). You should find a physical machine hosting Windows OS. Or you can try Parallels or Bootcamp but I can't guarantee that it will 100% work as VM on MacOS is not officially supported.
    • vivek310
      As I'm already using Solidworks in it without any problem as well as DesignModular is working fine in it . What I can do to run space claim properly is there any way to run it efficiently.
    • tsiriaks
      You are comparing apples to oranges. These are separate products.
      Go to
      https://www.ansys.com/academic/free-student-products
      and select the product you are using -> Minimum hardware requirements . This will guarantee you the expected performance
Viewing 3 reply threads
