Graphics Window BLACK
    • Naiara
      I installed ANSYS-FLUENT and everything went fine (geometry and mesh), but when I started with Setup step, Fluent Graphic Window is Black, I can not see residuals, contours, mesh  what can I do to solve it?
      Thank you in advance,
      Naiara
    • raul.raghav
      Naiara, I read that the black window was caused due to a graphics card issue. A similar discussion and the solution to the problem can be found here: Fluent’s Black Graphic Window
