April 12, 2022 at 6:59 pm
rajatkumar.sinha
SubscriberI am trying to find the grating coupling strength(α) for the Uniform grating coupler. In any grating coupler
April 13, 2022 at 10:36 pmGuilin Sun
Ansys EmployeeWhen you place monitors across gratings, due to lattice resonance (I called it), or bloch mode nature, the power does not monotonically decrease, in nature. However you can still see the trend as your last image shows. You could do some kind of average, say in a period and see if the result improves.
April 13, 2022 at 11:27 pmrajatkumar.sinha
SubscriberThank you for the suggestion. I took the maxima of all the oscillations(rather than average) and then tried curve fitting and that worked. Thank you so much!!
April 14, 2022 at 5:20 pmGuilin Sun
Ansys EmployeeYou are welcome! wish you a great success for your research.
- Error on Lumerical device
2724
2146
1357
1150
462
