Photonics
Photonics
grating S-parameters
    • djihad-amina.djemmah
      Hello, I have a question regarding the display of results. I am using the grating S-parameters  for my 3D simulations with 2000 frequency points, and my frequency range is from 200 to 400 GHz.
      The simulation takes a few hours, but after it finishes, the display of the results (S-parameters) also takes a few hours. Is this normal? Do you know why this might be happening?
      Thank you in advance
    • Greg Baethge
      Hi Amina,
      Thank you for posting your question on the forum. The main issue here is the number of frequency points: the grating S-parameter analysis group calculates the S parameters at each frequency, sequentially (basically, using a for loop in the analysis script), so with 2000 points, the loop takes some time!
      The first question would be whether you need that many point? Is that the case?
