gravity direction problem
    • mubasherrasheed70
      isometric viewisometric viewhere are the pictures of my meshed geometry. its cylindrical type. i am confused with gravity direction. Kindly suggest gravity direction
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      what is application? how this cylinder is placed in the system? where are inlets, outlets?
      Keyur
    • mubasherrasheed70
      its cylnrical tank in which a nozzle is present to inject steam into tank.' setup is horizonal with axial length along x axis
      Gravity is "down". So assuming +y is up then gravity will be -9.81 m/s2
    • mubasherrasheed70
      thanks
Viewing 4 reply threads
