April 26, 2022 at 8:38 am
MCFDHELP
SubscriberWhen i increase the angle of attack for an airfoil in fluent, the whole free stream increases in static pressure? Does anyone know why this happens?
Thanks
April 26, 2022 at 1:33 pmRK
Ansys EmployeeHello,
Can you please elaborate? Could you also insert images of pressure contour which will make us better understand your question.
April 26, 2022 at 1:41 pmApril 26, 2022 at 1:42 pmMCFDHELP
SubscriberIgnore the attachments, have inserted the photos into the message
April 26, 2022 at 1:50 pmRob
Forum ModeratorPlease post images of the outer boundary condition and domain size for both cases.
April 26, 2022 at 1:55 pmApril 26, 2022 at 1:56 pmMCFDHELP
SubscriberI have set the ground as a moving wall, the inlet as the curved and upper section and the outlet as pressure outlet
April 26, 2022 at 2:41 pmRob
Forum ModeratorCheck it's the same in both cases.
April 26, 2022 at 2:49 pmMCFDHELP
Subscriberyes i have checked it is the same for both cases
April 26, 2022 at 2:59 pmRob
Forum ModeratorCan you probe the second case too? Looking at the scale carefully, you could be looking at the same value but the scale is very different.
April 27, 2022 at 8:42 amMCFDHELP
Subscriberyou could be right, is there any way that i could verify this? as the scales are so different
April 27, 2022 at 10:42 amRob
Forum ModeratorPut a point into the domain and report the facet value. Display-Surface-Point, then use the Surface Report functions.
April 27, 2022 at 1:41 pmMCFDHELP
Subscriberi have done what you say, and they all appear to be around -2 to -6 pascals for the static pressure. The angle of attack varies from 0-9 degrees
April 27, 2022 at 4:37 pmRob
Forum ModeratorWhich is near enough the same.
April 28, 2022 at 9:45 amMCFDHELP
Subscriberdo you know why it is negative?
April 28, 2022 at 1:17 pmMCFDHELP
Subscriberor how to change the colours so they all show the same colour for free stream?
April 28, 2022 at 2:17 pmRob
Forum ModeratorIt's probably about zero so might be convergence related. In the contour plot deselect the "auto range" and add values manually.
April 28, 2022 at 2:53 pmApril 28, 2022 at 4:19 pmRob
Forum ModeratorThere's an option called "clip to range". Funnily enough if you have values outside of the manual range they disappear with that ticked.
September 28, 2023 at 6:27 amMani kiran
Subscribercan anyone help me to write the user defined function for a airfoil as it is landing as similar to the real case secenarioÂ
September 28, 2023 at 7:58 amRob
Forum ModeratorYou will need to be a lot more specific: what are you trying to replicate?
September 29, 2023 at 1:16 pmSeptember 29, 2023 at 1:19 pmRob
Forum ModeratorDo you need to solve the whole decent, or would several steady calculations be equally valid? The former will be a very long transient run, the latter some steady calculations.Â
September 29, 2023 at 1:21 pmMani kiran
Subscriberas you can see sir that i wrote a UDF for airfoil which is moving in straight path
Â
#include "udf.h"ÂDEFINE_CG_MOTION(airfoil,dt,vel,omega,time,dtime)Â{ÂÂ real t=time;Â ÂÂÂ vel[1]= -0.025*t;ÂÂ}Âso can u help me to write UDF which is similair to real lifeÂSeptember 29, 2023 at 1:29 pmRob
Forum ModeratorI'm still trying to understand why. All I'm able to do re UDFs is point you at the documentation.Â
September 29, 2023 at 1:29 pmMani kiran
Subscriberi think lets try with using the steady calculations , if its not efficient to what i want to figure out ,then we can proceed with the  long transient run .
September 29, 2023 at 1:34 pmRob
Forum ModeratorSteady will probably be quicker. Use the various NACA airfoil examples (Learning and Fluent Help) for guidance.Â
Viewing 26 reply threads- The topic ‘Ground Effect Fluent Simulations’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
