December 2, 2022 at 12:39 am
December 5, 2022 at 2:34 am
ChrisLee
SubscriberMaybe because you're edit in analysis group while "groupscope" can't used in here,you can just try "selectall;delect;"
"groupscope" can be used in Script File Editor.
December 5, 2022 at 5:55 pm
hany
SubscriberThat will delete all the structures under the model. The idea here is to only delete the elements inside a group structure using the script inside the "::model".
December 5, 2022 at 10:57 pm
ChrisLee
SubscriberMaybe selectpartial,shiftselect,or shiftselectpartial will work for you,you can have a try.
December 6, 2022 at 3:59 am
ChrisLee
Subscriberdeleteall;
for(i=1:3){
addrect;
set('name','rectangle'+num2str(i));
selectpartial('rectangle');
addtogroup('rec');
for(i=1:3){
addcircle;
set('name','circle'+num2str(i));
selectpartial('circle');
addtogroup('cir');
#1 for all the elements have the partial name "circle" in the same group;
selectpartial("cir::circle");
delete;
#2 select element one by one;
unselectall;
shiftselect("rec::rectangle1");
shiftselect("rec::rectangle2");
shiftselect("rec::rectangle3");
delete;
- Error on Lumerical device
2656
2120
1345
1118
461
