Photonics – Chinese
Photonics – Chinese
关于运行interconnect例子的问题
    • jiaqing.li
      各位老师好
      我在运行光网例子Circuit simulation incorporating component-level results(网址:https://optics.ansys.com/hc/en-us/articles/360042323574)时,按下图指示,完成了的waveguide.ldf的生成:
      此为waveguide.ldf的内容截图:
      在例子的根文件夹中也生成了'waveguide.ldf'文件,如下图所示:
      后按照指示运行gratingCoupler_sparameter.icp,但是程序却报错:
      发现问题是出现在'Mode Waveguide'模块中,但是在模块设置中,我却找不到对应设置描述文件的参数。
      烦请老师指导如何修改参数,能够正常运行程序!
      谢谢老师!
      祝好
      家青
    • jackzhf
      有沒有可能是沒有實施以下的操作?
      Calculate waveguide properties using MODE
      To characterize the waveguide (ie. mode profiles, dispersion, etc), open the waveguide_gc.lms project file in MODE.  Run the basic mode eigensolver to find the support modes of the waveguide.  Next, switch to the frequency analysis tab and click the Frequency sweep button to calculate the dispersion of the mode.  Finally, in the 'Options' property of the frequency sweep tab, select the Data Export option and click the 'Export for INTERCONNECT' button.  This will export all required data from MODE to a file that will be loaded into the 'MODE waveguide' object within INTERCONNECT.  The file should be named 'waveguide.ldf'.
