Hammer vibration
    • dillly96
      Hello all;
      I am trying to simulate a hammer vibration when a force is acting on the face of the hammer to see which material vibrates least when a force is applied.
    • peteroznewman
      In Workbench, drag and drop a Modal analysis onto the Model cell of the Static Structural analysis you have already done.
      In Mechanical, drag the Fixed Support under the Static Structural branch and drop it onto the Modal analysis branch.
      Solve. Create 6 Total Deformation results and set the Mode of each one to modes 1 - 6. (There is a shortcut to this if you look for it).
    • dillly96
      It has worked, thank you so much ­ƒæì
