September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeWhat is hard/soft behavior in ANSYS Meshing?
October 17, 2017 at 6:57 am
Arun
Ansys EmployeeThese behaviors are used regardless of whether the advanced size function is on or off. They are used in edge/face/body meshing. When you specify hard behavior Meshing will respect the prescribed element mesh size (and/or number of divisions for the edge meshing) on the entity. When soft behavior is used the size control may be affected by proximity, curvature and local re-meshing. The default behavior is soft.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2116
1337
1118
461
