hard turning
    • rupaknayak
      Sandeep medikonda sir plzz answer ??
      What i know is only mass and momentum conservation are monitered in explicit dynamics. then how are we able to calculate the temperature (user defined through worksheet) generated ???
    • Sandeep Medikonda
      Rupak, the temperature doesn't come from the explicit analysis but rather from the material model (plasticity or EOS).
      So, the specific heat is required and used to calculate temperature used in material models that include thermal softening (adiabatic heating). Check out the Docs on Johnson-Cook, Steinberg Guinan, Zerilli-Armstrong Strength materials.
      Sandeep
