April 17, 2023 at 8:08 pm
PARAS WADHVANI
SubscriberI need define Rockwool material as an absorber in Harmonic Acoustic Analysis.
How can i define in boundry condition?
And what type of region gor that?
Pls Help me asap...
April 18, 2023 at 9:16 am
Saumadeep
Ansys EmployeeHi Paras,
You will need to define the material "Rockwool" in Material properties and then assign it to the appropriate geometry of insulation.
To check how to define a material in the "Engineering Data" tab (as shown in the figure below), you can take a look at the following Ansys Help Link: 6.4. Material Properties (ansys.com)
Saumadeep Choudhury
April 18, 2023 at 9:24 am
Erik Kostson
Ansys EmployeeHi
To add, we need to use perforated material properties (e.g., DB, JCA or Miki material models) for the rockwool which is modelled.
The perforated materials are under engineering data. The material is then assigned as normal/usual to the corresponding body in Mechanical.
For a tutorial on using these see:
https://forum.ansys.com/forums/topic/acoustic-analysis-materials-problem/
All the best
Erik
May 15, 2023 at 10:18 am
PARAS WADHVANI
SubscriberHello,
What is require boundary condition for sound absorber material (Rockwool) In harmonic acoustic analysis.
May 15, 2023 at 10:21 am
Erik Kostson
Ansys EmployeeHi
There is no boundary condition to model Rockwool, what you need to do as we said and I hope it is clear, is to define the material “Rockwool” in Material properties and then assign it to the appropriate geometry/body representing the Rockwool.
To check how to define a material in the “Engineering Data” tab (as shown in the figure below), you can take a look at the following Ansys Help Link: 6.4. Material Properties (ansys.com)
All the best
3419
2473
1310
1022
