Harmonic Analysis – no rotordynamics content
    • raffikko
      Hi All,
       I have an issue with harmonic response analysis. I'm analysis student project of shaft with gear assembly. I have no rotordynamics content in Analysis Settings of harmonic response. For modal analyse  everything is ok.
      What could be the reason? Should it be performed via APDL?
    • jj77
      Make sure you have coupled the two (see image below), That is in order to do a harmonic analysis one needs to calculate the modes first (for mode superp. option) which can be then used by the harmonic analysis. If that is done in the harmonic analysis settings there should be a section for Rotordynamic controls (see yellow marking below). I think though to use the Coriolis effect (Rotrod. Controls), one needs to use the full solving method (thus modal and harmonic needs not to be linked like shown below, only a harmonic analysis is enough, one would still see the Rotrod. Controls though).
      If this does not help feel free to upload your model or some screenshots of what you are missing in the harmonic settings.
    • raffikko
      thank you very much for response.
      Please look on attachments.
      In my opinion it goes ok. Maybe it is Ansys bug? Connection Map, Harmonic analysis settings, Modal analysis settings and model.
    • jj77
      Which version of ansys are you using (perhaps 13 or 14, where this option is not possible as far as I can see)?
      Also one would need to use the full method to include Coriolis effect, thus try to use only a harmonic analysis with no links to modal.
    • raffikko
      It is 15th.
      I tried to do standalone harmonic but no rotordynamic again. Please look on photos:
      So similar results we can achieve in rigid dynamics analysis right?
    • peteroznewman
      raffikko,
      I expected to see a load in your harmonic analysis but I don't see one, so the Harmonic Response branch shows a ?
      What is the harmonic load to which you want to calculate the response?
    • raffikko
      Thank you for your support.
      I based on youtube movie:
      My goal was to find harmonic response from rotating force which is calculated from unbalanced mass.
    • peteroznewman
      Thanks for the video. Did you see him Insert > Rotating Force on the Harmonic Response branch?  That is the load your model is missing.
    • raffikko
      Ye, but I don't have this rotating force in my loads tree. Please look on photo:
    • peteroznewman
      Rotating Force was added after Release 15. You will have to use APDL commands such as CORIOLIS and OMEGA to define angular velocity input to the rotating structure. Here is the section in the ANSYS 15.0 help
      Here is a command object inserted with these commands
      Here is the Freq. Response in Y with the command snippet. It is the same magnitude in Z.
      Here is the Freq Response in Y without the Command Snippet. It is 1000 times smaller in Z.
      You can create Force in the Y direction (assuming your shaft is along the X axis). It is sufficient to have a single unbalanced force since it is rotating.
      Attached is the Release 15.0 model of an unbalanced shaft.
      Alternatively, you could download ANSYS Student 19.2 and use Rotating Force.
    • Hadi96
      Dear sir, i had insert the rotating force, but after generate it show that no hit point
Viewing 10 reply threads
