Harmonic analysis with a thermal load
    • andreapirocca
      Hello,nnI see that both in the Harmonic Acoustic and Harmonic Response modules in Workbench a thermal condition load is not supported. Is there a way to implement it with an APDL script, in order to obtain the frequency response of a structure with an oscillating thermal load applied?.Thank you,nAndrean
    • Ashish Khemka
      nnYou can insert in a command object with following commands:nn/solu (before solving in the Setup)nantyp,harmnharf,1nnsub,1nnsel,s,loc,x,0nd,all,temp,100 ! load will vary +/-100 nnsel,allnoutres,nsol,1nsavensolvenfininn/post1 (for post-processing)nset,lastnplns,tempnnRegards,nAshish Khemka
