Harmonic Response: different result in animation and results tab
    • bjarne321
      I want to use a parameter set in a harmonic response to calculate the resulting velocity of an edge at different excitation acceleration. The maximum velocity in the results tab is way to low.
      Result tab
      When i start the animation of my part moving the shown result next to my geometry is changing to the right value.
      result when pressing play
      Is there a way to output the correct value in the results tab and use it in parameter set?
Viewing 0 reply threads
