April 26, 2023 at 10:17 pm
May 2, 2023 at 7:40 am
Sahil Sura
Ansys EmployeeHello Maria Fernanda Velasquez,
Harmonic analysis helps to solve for the structure's dynamic response in the 'Frequency domain' instead of the time domain. This many times is helpful to get the characteristics of the system with an efficient solution as time domain-based analyses can be computationally expensive for an extensive range.
Thus, the results obtained would be computed at different frequency values.
If you are interested in the fatigue life of the component, you can get the time value for life for a certain frequency using the 'Fatigue Tool'.
Converting the problem into a time domain to get the respective results would be helpful in addressing the situation. You can go for a transient analysis with the respective input sinusoidal loading to get the required results. This can be computationally expensive though, so an MSUP Transient would also be helpful to get the dynamic response of the system.
The following resources might be helpful in addressing the issue,
Harmonic Response Analysis (ansys.com) Correctly Interpreting Harmonic Results - Lesson 2 - ANSYS Innovation Courses
Time and Frequency Domain Dynamics – Lesson 2 - ANSYS Innovation Courses
Mode Superposition Transient Analysis | Ansys Courses
Transient Structural Analysis (ansys.com)
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5162
3275
2453
