October 5, 2018 at 7:52 pm
masud407
SubscriberHello Peter,
I have a basic inquiry regarding harmonic response analysis in ANSYS. When we provide a magnitude of acceleration/displacement in any particular direction (X/Y/Z), does it mean a sinusoidal input or a step input?
October 5, 2018 at 7:55 pm
SubscriberHello,
Your original Discussion got too long, so I moved your new question here.
A load in a harmonic response analysis is a sinusoidal input of the amplitude of the sine function.
November 29, 2018 at 10:06 am
kiarashniroumand
i have a problem in applying force in a harmonic response simulation
the simulation is based on frequency response of a cantilever beam which has a fan on it that vibrates because of an unbalanced mass
as you know an unbalanced mass produces a force like this F=(m*e*w^2)sin(w*time) where w is the excitation frequency
the problem is in amplitude of the harmonic force , it is varying with frequency by a second order equation
as i wanna get the frequency response deformation , it becomes important to define the frequency varying amplitude
but in workbench 18.2 there is no choice to apply amplitude as a function of frequency , it has just constant and tabular data choice
the tabular data can be varying by frequency simply , but it is so hard to define the load like this below
frequency=1 hz , z component force=1
frequency=2 hz , z component force=4
frequency=3 hz , z component force=9
frequency=4 hz , z component force=16
frequency=2000 hz , z component force=4000000
is there any way to define it easily by a function and expression ?
November 29, 2018 at 1:26 pm
SubscriberHello k,
Use Excel. In column A, put 1, 2, 3... 2000 and in column B put the equation you want: A*A for example.
Copy the 2000 rows x 2 column cells and paste into the Tabular Data window in Workbench.
That's pretty easy right?
P.S. It's better to start a New Discussion because then you "own" the discussion and get notified of replies.
2146
1357
1150
462
