June 8, 2020 at 3:18 pm
mbuys980411
SubscriberI am trying to model a rubber mount using the Harmonic Response in ANSYS. The one end of the rubber mount is fixed while the other is vibrated with a motor. I want to model the behavior of the material using the Mooney Rivlin 2 parameter material model. I am using a Harmonic Response because I want to be able to change the frequency of the applied deflection at the non fixed end. However I get an error that I need to add elasticity to the material model in order for the Harmonic Response to solve. Could I do the same thing with Transient Structural or Static Structural since I don't have elasticity data for my experiments?
June 8, 2020 at 6:21 pm
SaiD
Ansys EmployeeHi,
Could you share an image showing how the material model has been defined? If you are using Mooney-Rivlin 2 parameter model, you need to either define the two parameters or provide experimental data from which those two parameters can be calculated (by curve-fitting). If you don't have the material properties then no FEM analysis (Transient Structural, Static Structural etc.) can be performed.
June 8, 2020 at 7:25 pm
November 19, 2020 at 7:10 pm
JHPontes
SubscriberHi, nSame problem herenDid you figure it out ?n
3648
2534
1745
1226
578
