December 8, 2020 at 2:59 am
ah05085
SubscriberHello all, nIm having trouble with conducting a simulation. I have 2 errors. My first error has to do with the solver engine was unable to converge due to a nonlinear constraint. The other error is regard an element being highly distorted. n -
December 9, 2020 at 3:54 am
SubscriberArray nThese are both very common errors with well known corrective actions.nHere is the Google Search results for the term unable to convergenhttps://www.google.com/search?ei=1SvQX4vAI-zF_QaE6ZPQDw&q=site%3Aforum.ansys.com+%22unable+to+converge%22nHere is the Google Search results for the term highly distortednhttps://www.google.com/search?ei=TkrQX8iSFYPX5gLknIgI&q=site%3Aforum.ansys.com+%22highly%2Bdistorted%22n
- The topic ‘Having issues with transient structural simulation of a e motor rotor.’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8832
4658
3159
1688
1482
