3D Design
3D Design
having Problem in converting it into solid and split it
    • Zenith
    • peteroznewman
      On the Facets tab, use the Holes button. Select the Cap radio button on the Options panel if you want a flat face. That will create a Facet body from a Facet surface.
      You can't mesh facets, you need to convert it to a solid, but it is much better to skin the facets with larger faces than directly convert facets to small triangular faces. The most automated way to do that is on the Tools tab, use the Auto Skin button.
      On the Design Tab, you can use the Split Body tool on the Patch body that was created.
