Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Having problems implementing a hex mesh with inflation
    • rachels1001
      Hey guys,
      I am having an issue with creating a hex mesh for this geometry.
      My problem is that I also have to include inflation layers at the walls of the central body. Hex dominant methods are not compatible with inflation, and when I've been trying to implement a multi-zone mesh, it tells me that the meshing is failing. I've enabled free mesh type in the multi-zone mesh.
      I feel like I probably need to slice the central geometry to implement the multi-zone mesh, but I'm a little confused about how I should slice it and how to select the source faces?
      I've gone over the multizone mesh pages on Ansys help, any help is appreciated!
      Thanks,
      Claire
Viewing 0 reply threads
