March 6, 2021 at 9:25 pm
Khan_AH12
SubscriberMarch 8, 2021 at 12:49 pmANSYS_MMadore
Ansys EmployeeArray Could you please open a Windows command prompt and run the command set without quotes and send the full output? Could you refer to this post to see if it may apply in your case? https://forum.ansys.com/discussion/comment/92545#Comment_92545nPlease also try this, make sure all ANSYS applications are closed, then try registering the DLL's by starting a Command Prompt with run as administrator , and issuing the following commandsnregsvr32.exe ole32.dllnregsvr32.exe atl.dllnregsvr32.exe oleaut32.dllnregsvr32.exe scrrun.dllnregsvr32.exe jscript.dllnregsvr32.exe vbscript.dllnNovember 20, 2022 at 7:15 pmNovember 22, 2022 at 1:16 amMAHESH BALASURIYA
SubscriberI saved in attched draft full issue
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2656
2120
1347
1118
461
