October 7, 2018 at 3:20 am
jmillie
SubscriberHey, I just started using ANSYS Mechanical for a class.
We are creating a Truss using only LINK180 elements. I need to constrain one of the nodes in the UX,UY,UZ,ROTX,ROTY,& ROTZ directions. However, when I apply the displacement constraints on the node, I only have the option to contrain the UX,UY,UZ, VELX,VELY,VELZ directions. ANyon know what setting I need to change so that I can constrain in the ROT directions?? thanks
October 7, 2018 at 5:59 am
SubscriberHey,
A LINK180 element only has UX, UY, UZ degrees of freedom at each node. No rotation is computed by the element.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
459
