May 23, 2023 at 10:15 am
Hermann Lochmann
SubscriberHello everyone,
I'm trying to use the HDF-import feature for a methods comparison.
In the first trys, I create a single ply with orientation, material etc. After that, I export the model to HDF5-format.
The main model will consist of a bigger structure where i want to map a few of the exported single plys. But when I do, I always get the message:"Failed to import ACP model from HDF5 file ... : Unable to find key in unordered map"
The Preview works well and I can the the mesh from the single ply. When I import the HDF-File to Hypermesh, there is no mesh, but all the other data. So I can easily apply the data to a mesh and it looks like it should. So I think there are all informations in that file, but ANSYS ACP could not handle with his own export.
I hope someone has an idea and can help me.
May 24, 2023 at 11:26 pm
Reno Genest
Ansys EmployeeHello Hermann,
If I understand correctly, you are trying to export the HDF5 from Ansys ACP and import into Hypermesh correct?
You get the error above when trying to import in Hypermesh?
Reno.
3299
2469
