HDPE Foam Material Properties
    • UTKARSH PATEL
      Does Ansys Have material properties available of an HDPE Foam that has 4lbs per cubic feet density. I am running some analysis and I need further material properties to solve material related errors I am seeing. Currently I only have density added under added material.
    • Aniket
      Hi Utkarsh, Material properties are input, and should be coming from actual material testing data. Sample material data we provide, is sample and is for reference, only.
      -Aniket
      Forum Rules & Guidelines
    • UTKARSH PATEL
      Hi Aniket, Sounds good. Thank you.
