November 7, 2023 at 2:58 am
dmao
SubscriberHi there,
I failed to find 3D waveguide HEAT simulation examples. Would you be able to provide some relevant examples using 3-D HEAT solvers?
Thank you,
Deng
November 8, 2023 at 9:41 pm
Amrita Pati
Ansys EmployeeHi Deng,
Here is an an example of 3D HEAT simulation that simulates multiple ring waveguides: Thermal Switch.
I see that there are some other 3D HEAT simulations but they are not waveguide simulations. Let me know if you want their links as well.
Amrita
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
