March 29, 2018 at 4:27 pm
papp
SubscriberHello,
I've experienced that Discovery Live is not able to calculate any heat transfer at all if its thermal conductivity is decreased below a certain value. (In the order of magnitude of 10^-5.) This results in a constant 0 [°C] temperature field, however several heat sources are added to the computation domain. Note, that with higher values heat transfer works just fine. Fidelity set to maximum, GPU: GTX 1080Ti.
Can you provide any solutions to this problem, or at least confirm this phenomenon as a known limitation of Discovery Live?
Thanks,
Bálint
March 29, 2018 at 9:58 pm
Brian Bueno
Ansys EmployeeI will consult with our development team and get back to you. I assume the value may be too small if it works with larger ones.
March 30, 2018 at 12:16 pm
anthony.giacoma
SubscriberHi Bálint,
Thanks a lot for your feedback! I hope that you enjoy Discovery Live experience.
A material with a thermal conductivity, say λ, such that λ < 10^{-3} is very very very powerful insulation material. You set λ = 10^{-5}, why not :) . As the heat cannot be transferred because of this huge insulator, I guess that you won't be able to see any degree elevation through the bulk of the solid due to heat sources.
Maybe, I'm missing details. Could you share with us additional details about your observation (screenshots, problem set) ?
Thanks a lot
March 30, 2018 at 9:46 pm
papp
SubscriberHello, at first, some clarification: I'm simulating the propagation of air pollutants in Discovery Live, in the field of air quality oriented urban design. To achieve this goal, a diffusion-heat trasfer analogy has to be used, obvioulsy. (Fluid module with heat transfer.) In this analogy, the temperature of air represents the air pollutant concentration, and the heat fluxes at certain areas the pollutant source zones. As you might know, this analogy exists for the transport coefficients in kinematic unit, [m/s^2], namely:- D, the diffusion coefficient of air;
- λ/(rho*c_p), [thermal conductivity]/([density]*[specific heat]) of air (for heat transfer).
March 30, 2018 at 9:48 pm
papp
SubscriberKinematic unit is [m^2/s] correctly.
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
- Unexpected graphics error
5368
3363
2471
1310
1020
