September 6, 2022 at 10:14 am
al1419
SubscriberHi all, this is meant to be a thermal analysis of the molten metallic alloy in a pipe but it seems as though the conduction feature is not working out despite using coupled walls for the fluid walls and the pipe's inner walls. This is what I did during the pre-processing stage:
- volume extract inside the pipe to generate the fluid volume. The pipe is meshed with the fluid
- create named selections - inlet,outlet,pipeinnerwalls, fluidwalls
- This later autogenerated coupled conditions for the wall/shadowwalls
I ran the simulation with my velocity-inlet and pressure-outlet conditions and I think these are correctly assigned considering the results of the first image. Please does anyone know why heat conduction through the walls is not working? I don't think I'm able to use shell conduction as there's an already assigned thickness to the walls from the mesh.
September 6, 2022 at 10:18 am
September 6, 2022 at 10:44 am
Nikhil Narale
Ansys EmployeeDid you turn on the energy equation? If yes, what are the thermal boundary conditions? Also check if the cell zone for pipe has been assigned with the correct material (and material properties).
Nikhil
September 6, 2022 at 10:53 am
September 6, 2022 at 11:28 am
Nikhil Narale
Ansys Employee'I don't think I'm able to use shell conduction as there's an already assigned thickness to the walls from the mesh.'
If you are explicitly meshing and solving for the solid pipe domain, you don't need to use shell conduction.
Can you post a screenshot of the temperature contour?
Make sure you assign appropriate thermal boundary condition on the outer pipe wall as well.Nikhil
September 6, 2022 at 11:35 am
September 6, 2022 at 11:39 am
Nikhil Narale
Ansys EmployeeThere you go. With heat flux = 0 there will be no heat transfer and you won't get the desired temperature distribution. If you know the temperature of the outer wall, go with the Temperature condition, else go with the Convection condition.
Nikhil -
September 6, 2022 at 11:41 am
Nikhil Narale
Ansys EmployeeBasically, assigning heat flux = 0 tells the solver that the walls are insulated.
September 6, 2022 at 1:59 pm
al1419
Subscriber-
September 6, 2022 at 5:09 pm
Nikhil Narale
Ansys EmployeeInstead of the outer wall, plot pressure contour on the inner wall of the pipe.
September 6, 2022 at 10:39 pm
al1419
SubscriberThank you!
I also have another issue with post-processing if you don't mind kindly looking at it. Whilst looking at the temperature distribution of this certain pipe, I've applied a 330 degree velocity inlet BC to the two pipes shaded in dark blue and a pressure-outlet at the end shaded in red. However the temperature distribution suggests the fluid's temperature increases? I don't think this makes sense. Is there something wrong with my initialization method? I used hybrid initialization and the velocity-in and pressure-out are the only BCs I used
September 7, 2022 at 4:51 am
Nikhil Narale
Ansys EmployeeI think you are monitoring the temperature on the outer pipe and not the bulk fluid temperature along the length. If you want to check the temperature change for fluid, check for temperature at the inlet and the outlet.
Nikhil
September 7, 2022 at 6:43 am
September 7, 2022 at 7:04 am
Nikhil Narale
Ansys EmployeeTemperature contours won't give you a correct picture in this case. Can you check the mass-weighted average of the temperature at the inlet and outlet of the fluid domain?
September 7, 2022 at 8:59 am
September 7, 2022 at 9:07 am
Nikhil Narale
Ansys EmployeeYou should get 4 different values (2 for inlets and 2 for outlets). Assign the reports separately and not combined.
However, for inlets, it will be the same as the boundary condition. Look out for outlets.
Btw, what is the thermal boundary condition on the outer pipe wall? -
September 7, 2022 at 9:17 am
al1419
Subscriber -
September 7, 2022 at 9:30 am
Nikhil Narale
Ansys EmployeeThere are 2 different pipes, right? Correct me if I am wrong.
September 7, 2022 at 9:33 am
al1419
SubscriberYes there are. I see, when applying the outlet boundary conditions in the pre-processing stage, I applied 1 named selection to all 'outflow' faces of the fluid. Is this incorrect and instead I should apply 1 named selection to each face? (think this might the issue)
September 6, 2022 at 11:45 am
al1419
SubscriberOh I see, thank you so much! I'll let you know of the outcome
Many thanks,
Annie
2524
2066
1279
1096
457
