July 3, 2019 at 4:18 pm
ZoeYuan
SubscriberHi,
I am simulating catalytic surface reaction of CO, C3H6 and NO in a micro-channel model. There are two domains in my model: the fluid domain which is the reacting flow and the solid domain which is the channel wall. I set coupled interface and then two contact regions auto-generated under the wall boundary conditions with the name of contact_region-src and contact_region-trg. I would like to ask if I want to set heat convection for the interface, do I need to set the heat transfer coefficient for the src side or trg side? Also, do I need to set the material name here to be my channel wall material which is ceramic.
Here is the screenshot of my boundary conditions.
Zoe
July 3, 2019 at 4:19 pm
Ansys EmployeeMoved to new thread.
If you have a coupled wall between fluid & solid Fluent should calculate the convective heat transfer. If you set a value you're artificially fixing something that's a function of the fluid flow.
July 4, 2019 at 9:42 am
ZoeYuan
SubscriberHi rwoolhou,
Many thanks for your reply.
Does this mean that I don't need to set anything for the thermal condition once I created a coupled wall between fluid & solid and just leave it blank?
Zoe
July 4, 2019 at 9:58 am
Ansys EmployeeYes: you should leave that as coupled. I'd also review the wall thermal boundary conditions and shell conduction: do you really need to model the solid bit?
July 4, 2019 at 10:29 am
ZoeYuan
Thanks for your quick reply.
This is a simplified version of my model. The original model is a heat exchanger and I need to consider the effect of different wall material on heat transfer between the flow and wall. Also, I am simulating catalytic surface reaction. In this case, do you think it's necessary for me to model the solid domain?
Zoe
July 4, 2019 at 11:04 am
Ansys EmployeeDifficult to say: partly because I can't see the model but also I'm not allowed to give detailed advice due to US export law.
Heat transfer from the fluid to solid is handled in the solver & wall functions: avoiding an interface there is a good idea but not a requirement. Also read up on y+ and wall functions (turbulence sections of the manual).
Heat through the solid is a function of the material conductivity and surface area: we can use thin walls with a thickness, shell conduction or solid zones.
July 4, 2019 at 5:02 pm
ZoeYuan
SubscriberMany thanks for your explanation.
I need to consider the heat dissipation from the channel wall to surrounding environment -air. In this case, do I need to construct an enclosure surrounding my model to represent the heat dissipation from wall to air? Or is there any other way to simulate the heat dissipation?
Zoe
3930
2649
1863
1272
610
