March 31, 2023 at 10:35 am
Sarah Skoff
SubscriberHi everyone,
We are trying to simulate a plasmonic structure with DGTD and analyse its thermal response to Joule heating simiarly to the example in the Application Gallery (Photothermal heating in plasmonic nanostructures (DGTD) – Ansys Optics)
However, if we import the absorbed optical power and scale it to a factor which is appropiate for the structure the HEAT simulation throws up an error with code: 0xc0000005 and the additional message:
C:\Program Files\Lumerical\v231\bin\thermal-engine-msmpi.exe
As I understand that error is linked to a access violation in Windows. Has anyone of you any idea how to fix that?
Running Win 11 Pro (Version 22H2) and Lumerical 2023 R1.2 to which I updated to this week.
Additionally, the same error is raised if we try to run the simulation at our Server which runs an older 2022 R2.4 version of DGTD/HEAT on a Windows Server 2016 operating system.
Thank you very much in advance.
Fritz
April 4, 2023 at 5:02 pm
Lito Yap
Ansys EmployeeTry to save the simulation/project files on the local drive of the computer running the simulation, not on a network or cloud drive (like OneDrive, DropBox, etc) or a folder that has to sync to a different drive.
April 11, 2023 at 6:11 pm
Khashayar Ghaffari
Ansys EmployeeHi Sarah,
Just checking in to see if you need further support here. Please let us know if you have further questions.
Best,
Khash
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5346
3345
2471
1310
1016
