June 15, 2022 at 9:52 pm
dkattim1
SubscriberI have to two rectangular blocks in 3D. One on top of other (stack electronics). I know the heat flux at the interface.
But I cannot add heat flux at surface as it would violate coupled condition in thermal, How can I apply this boundary condition?
Only option is with some thickness and Volumetric heat generation. Kindly help -
June 17, 2022 at 1:00 pm
Ansys EmployeeIf you know the flux at that surface why are you modelling the solid part? -
June 21, 2022 at 9:47 am
DrAmine
Ansys EmployeeEither you leave that default and consider Conjugate Heat Transfer or you remove the Solids and just use the Heat Flux as Input as mentioned by Prof. Robert.
3930
2649
1869
1272
610
