March 11, 2021 at 12:27 am
DannyOuk
SubscriberHello, nI am currently simulating a 2D axisymmetric geometry. When applying the heat flux boundary condition on a wall that has a thickness, is the heat flux value being applied on the inner side of the wall or on the outer side of the wall, which would have a greater radius? nThanks for the help. nSincerely, nDannyn -
March 11, 2021 at 2:20 pm
Ansys EmployeeThe flux is applied to the surface area of the surface it's assigned to. If you're using thin wall but giving it a thickness the area is as per the geometry:the thickness is purely for conduction and has no geometric presence. n -
March 12, 2021 at 1:17 am
DannyOuk
SubscriberI understand. Thank you for your help! n
Trending discussions
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
