September 26, 2018 at 9:05 pm
desouzadacosta
SubscriberHi All,
I am trying to simulate a disk braking inside a fluid-domain.
I imposed a variable heat flux in a portion of the surface of the disk that
I named as brake-pad (a wall adjacent to the solid zone). Fluent automatically
changed the thermal b.c. for the brake-pad-shadow to 0 heat flux. Is that
the way to go ? Any comment of FLUENT experts are very welcome.
thxs.
P.S. The disk is entirely inside the fluid domain.
September 27, 2018 at 6:11 am
Konstantine Kourbatski
Ansys EmployeeIndeed, Fluent will decouple wall and its shadow when you attempt to prescribe a thermal condition other than coupled. To specify a heat source and preserve thermal coupling between wall and its shadow, you can
1) apply volumetric heat source to a layer of cells adjacent to the wall
2) specify the wall as shell conducting, and apply heat source to the virtual shell cell zone
Both approaches will require either domain decomposition or UDF to prescribe heat source in a desired region. You'll also need to heat flux input into volumetric heat source data
2656
2120
1349
1118
461
