August 8, 2019 at 6:31 am
Gate9er
SubscriberHello guys
How do I generate a heat flux contour plot at the inlet area of a water pipe? I want to include both the pipe and fluid in the plot.
Thanks
August 8, 2019 at 9:52 am
Ansys EmployeeYou can plot temperatures, what do you expect from a heat flux on a fluid boundary?
August 8, 2019 at 9:55 am
Gate9er
SubscriberI want to mainly observe the heat flux in the pipe (ignore the fluid) as a result of the temperature variation. This will indicate which locations are redundant within the pipe so that unnecessary material can be potential removed.
Thanks
August 8, 2019 at 11:51 am
Ansys EmployeeHeat flux to where? It's usual to plot temperatures or HTC (with caveats: read the field definitions).
August 8, 2019 at 11:53 am
Gate9er
SubscriberHeat flux from the outer pipe wall to the inner one.
August 8, 2019 at 2:24 pm
Ansys EmployeeHave a look in the Wall Fluxes and read the definitions.
2524
2066
1279
1096
457
