June 19, 2019 at 4:39 pm
sleontsi
SubscriberHi all,
First post, so apologies for any ignorance in advance.
I'm trying to implement a variable heat load of an object, generated as a function of the object's temperature. I figure out that I can't do it with a steady-state or transient thermal simulation, as in the formula that I can write as load, the object's temperature can't be an input. So, I guess the "Fluid Flow (Fluent)" is the only option? Do I have to write my own UDF script and load it? Is there a template somewhere that I can use?
Thanks a lot!
June 20, 2019 at 10:25 am
Ansys EmployeeWhat are you trying to model?
June 20, 2019 at 11:54 am
sleontsi
SubscriberAt this point I'm simulation a pipe and two blocks of silicon. The first block is generating constant heat and I'd like to model the heat generation of the second block, as a function of its temperature.
Thanks for the reply!!
June 21, 2019 at 12:24 pm
Ansys EmployeeYou can probably use an expression (Fluent 2019) to link temperature to heat flux (source term) but adding heat will add to the temperature so may not be overly stable.
June 24, 2019 at 12:48 pm
sleontsi
SubscriberThanks for the reply! I'm not sure though how the structure of the UDF works.. How the temperature calculated by ANSYS is linked with the variables in ANSYS. Is there an example that you can point me to?
Thanks again!!
June 24, 2019 at 3:17 pm
Ansys EmployeeThere are examples of various codes in the UDF Manual: look in the section on Source terms. There may not be a temperature dependent function, but behaviour is the same as for position etc, you just use a different macro.
June 25, 2019 at 5:00 am
sleontsi
Subscriberthanks a lot for the hint!!
June 25, 2019 at 12:14 pm
Ansys EmployeeYou're welcome. When you figure it out please post the code for others to use: feel free to hide the actual equation just leave enough that it's clear how the flux and temperature are linked.
July 5, 2019 at 2:37 pm
sleontsi
SubscriberSo, I used a UDF and the methods DEFINE_PROFILE, C_CENTROID and F_PROFILE. Each cell's temperature can be derived by C_T(c,t) and applied with a formula based on F_PROFILE(c,t,i).
3776
2573
1825
1242
598
