March 18, 2022 at 5:33 pm
RBJ
SubscriberHello,
I have a model of a tunnel. When running in transient, heat loss is being modeled through the walls. When switching the run to steady-state (the only difference), suddenly no heat is being lost through the walls. Is this a quick fix? Am I missing something simple or is more information needed on the model?
Thanks
March 21, 2022 at 11:54 amRob
Ansys EmployeeIf the transient model worked, but steady didn't check the temperature field. Steady is the equilibrium result so if there's no heat being added via a boundary/cell condition you won't see any heat transfer.
2726
2156
1359
1150
462
