February 28, 2023 at 8:18 am
February 28, 2023 at 5:29 pm
Andreas Koutras
Ansys EmployeeHello,
The settings in the second picture look correct. Here is an example:
Could you deactivate the ShaEle option in the bottom left corner by selecting the HidEle option and then activate ShaEle again. Then fringe again.
Also reverting to the default configuration settings may help.
Trying a new LSPP version may also help.
Let us know how it goes.
Thanks.
February 28, 2023 at 8:29 pm
Luisa Hornung
SubscriberDear Andreas,
(de-)activating HidEle did not help and when I try to reset the setting, LS Prepost crashes.
After updating to 4.9 I could reset the settings and now everything is working fine.
Thank you for your help!
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3670
2552
1751
1232
584
