September 27, 2023 at 8:35 pm
Josias Eilers
SubscriberIf I have added a new liquid and specified the properties: density, Cp, thermal conductivity and viscusity,
are these sufficient to carry out a heat simulation in ansys fluent,
in which everything necessary is taken into account to achieve a correct result?
Even if the aggregate states change during the simulation? -
September 28, 2023 at 8:14 am
Forum ModeratorIf it changes state you'll need the vapour properties & enthalpy (latent heat) and the phase change models. Assuming all of the boundary conditions etc are also set.
I advise going through the thermal course on Learning and looking at the various tutorials in Fluent's Help system.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
