February 15, 2021 at 9:26 pm
rouzbeh
SubscriberHi everyone,nis it possible in fluent to difine the heat source inside the solid(not on the surface) part (wall) which is constant in x-direction and variable in y-direction? if it is only possible using udf, could please help me.nRegardsn -
February 16, 2021 at 12:31 am
YasserSelima
Subscriberyes, you can do it. If you are using 2019R1 or later, you can use expression and you don't need a UDFn -
February 16, 2021 at 2:50 am
Keyur Kanade
Ansys EmployeePlease check following nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
February 16, 2021 at 1:08 pm
rouzbeh
SubscriberThank you very much . Yes, I am using 2020R2 but could you please explain me how can I write an expression for heat source gradient as a function of location (in my case x and y because it is 2d)?nRegardsn n -
February 16, 2021 at 1:42 pm
YasserSelima
Subscribernwatch this webinar nhttps://www.ansys.com/resource-library/webinar/expressions-simplify-simulations-fluent-2019r1n
5340
3325
2471
