heat source
    • bobd
      Hi all,
      is it possibile to have a time dependent heat source like this?
    • RK
      Yes, it is possible.
      Rahul
    • bobd
      And do I have to do the derivation like I did?
      No, you can put in anything you want. However, I find it best to use a sensible value.
    • bobd
      and if you work with a volume of fluid model, is there a way to apply this heat source only to one phase?
      Kind regards
    • DrAmine
      In VOF you have single temperature equation so the weighting with volume fraction would only make sense for interracial cells (from one to N cells depending on the scheme).
      Your UDF is wrong.
    • bobd
      In VOF you have single temperature equation so the weighting with volume fraction would only make sense for interracial cells (from one to N cells depending on the scheme). Your UDF is wrong.
      What would you suggest to solve the problem of heating source in one fluent in a 2 phase model?
Viewing 6 reply threads
