Heat Transfer
    • Lekkss
      How can I check the heat transfer in a roof(3-d) using the roof, ceiling inclusive as case study
    • Keyur Kanade
      Please check Results --> Reports --> Fluxes
      Please check help manual for detailed information.
      Keyur
    • Lekkss
      Thanks, the main thing I need is the nusselt number. Do you have any idea on how
      Use the surface integrals. Note read the documentation to understand how the Nusselt Number is calculated as the reference values may not match the ones in your experiment.
Viewing 3 reply threads
